Lehrreich
helmutsennewald
R.I.P.
Ehrenmitglied
1pole_noise.asc
4pin-opamp.zip
ac_ math1.zip
ac_math.zip
ac_resistance_conductance.asc
adc_8bit_test1.zip
Adjust_vbe.asc
AO4468_test.zip
basics_ac.asc
basics_tran.asc
B_function.asc
Bipolar_Transistor_with_temperature.zip
bit_stream.zip
Cap_discharge.asc
cap_tan_d0.asc
cap_tan_d.zip
Constant_phase_element1.asc
Control Theory.zip
Crystal_oscillator.asc
csd10060_test.asc
Dead-time.asc
Digital Latch.zip
diode_with_table1.asc
early_voltage1.asc
epoly_1.asc
ESR_freq1.asc
Eye Diagram.zip
fft_am_signal.asc
flicker_noise_2N3904_BC850.asc
Flicker_noise_simulation_bipolar_transistor.zip
FM_voltage_source.asc
foldback_simulation.zip
Fourier1.asc
Frequency measurement by FFT.zip
From netlist to schematic.zip
ft_mos.zip
gauss_sub2.asc
g_b_table.asc
GND_port_pin_sim1.zip
Hierarchical Schematic (preamp).zip
highpass.asc
hspice_lib.zip
ideal_amps1.asc
IF_filter455k.asc
impedance_measurement1.asc
impedance_measurement1.plt
individual_temp1.asc
individual_temp.asc
individual_temperature_of_mosfets.asc
inductance_vs_time.asc
init_cap_volt.asc
initial_ic.asc
initial_uic.asc
IRFP244_EKV_rev1.zip
jfet_amp_hierarchical.zip
Jfet_and_loadline.zip
jfet_model.asc
JFET tolerances.zip
LAPLACE1.ASC
loopgain.html
LoopGain_others.zip
LoopGain_Probe.zip
lp5_phase.zip
LTspice_Educational.pdf
LTspice_VDMOS_param_ksubthres.zip
Mains Filter2.asc
Min_vdrop_vs_temp.zip
Model_change_param_ako.asc
Model_Selection_ako.asc
Modulated Sawtooth Generator.zip
Mosfet_capacitance_ciss_coss_crss1.asc
Mosfet_cap_ciss_coss_crss1a.asc
MOSFET parameter sweep.zip
mos_param_visibility.asc
moving_average1.zip
nand_osc1.asc
nmos_model.asc
NoiseFigure_opt1.zip
opamp_rout.asc
oscillators.zip
passing_params_hierarchy_2.asc
passing_params_hierarchy_2p.asc
Photo Diode Simulations.zip
pi-controller-2.asc
pi_e.asc
pink_ac_source.asc
plot_ energy_charge_flux.zip
Plot Panes.zip
Power-Factor.asc
pwm.asc
PWM_FREQ_DUTY1.asc
QTLP690C_Eg.asc
Quadrature_fm_demodulator.zip
Ramp_table_if.asc
rdson_temp.asc
R-formula_time.asc
rout_dc_op_tf_ac_tran.zip
shot_noise.asc
skin_effect2.asc
solar_diode_check.asc
stepped_plot_panes.zip
step_recovery_diode.asc
Sweep with_B-source_Modulate.asc
SW_subckt.zip
tc_of _res.asc
TIA_universalopamp2.asc
Time domain noise sources.zip
time_var_resistor.asc
too_high_gmin.asc
Transient analysis of a crystal.zip
Transistor Model 2N6517.zip
Transistor Models 2N4401.zip
triggered_pulse__v_tline_bv.asc
URC_line.asc
Using Infineon OPTIMOS models.zip
Using MOSFET models.zip
vco_table_poly.asc
view_param.asc
voltage_periodic_ramp1.asc
white_gauss1.asc
Z-imp-freq table.zip
Z_imp_test_mag_r_i.zip
zin_rlc1.asc
  • 1pole_noise.asc
  • 4pin-opamp.zip
  • ac_math.zip
  • ac_ math1.zip
  • ac_resistance_conductance.asc
  • adc_8bit_test1.zip
  • Adjust_vbe.asc
  • AO4468_test.zip
  • basics_ac.asc
  • basics_tran.asc
  • B_function.asc
  • Bipolar_Transistor_with_temperature.zip
  • bit_stream.zip
  • Cap_discharge.asc
  • cap_tan_d.zip
  • cap_tan_d0.asc
  • Constant_phase_element1.asc
  • Control Theory.zip
  • Crystal_oscillator.asc
  • csd10060_test.asc
  • Dead-time.asc
  • Digital Latch.zip
  • diode_with_table1.asc
  • early_voltage1.asc
  • epoly_1.asc
  • ESR_freq1.asc
  • Eye Diagram.zip
  • fft_am_signal.asc
  • flicker_noise_2N3904_BC850.asc
  • Flicker_noise_simulation_bipolar_transistor.zip
  • FM_voltage_source.asc
  • foldback_simulation.zip
  • Fourier1.asc
  • Frequency measurement by FFT.zip
  • From netlist to schematic.zip
  • ft_mos.zip
  • gauss_sub2.asc
  • g_b_table.asc
  • GND_port_pin_sim1.zip
  • Hierarchical Schematic (preamp).zip
  • highpass.asc
  • hspice_lib.zip
  • ideal_amps1.asc
  • IF_filter455k.asc
  • impedance_measurement1.asc
  • individual_temp.asc
  • individual_temp1.asc
  • individual_temperature_of_mosfets.asc
  • inductance_vs_time.asc
  • init_cap_volt.asc
  • initial_ic.asc
  • initial_uic.asc
  • IRFP244_EKV_rev1.zip
  • jfet_amp_hierarchical.zip
  • Jfet_and_loadline.zip
  • jfet_model.asc
  • JFET tolerances.zip
  • LAPLACE1.ASC
  • LoopGain_others.zip
  • LoopGain_Probe.zip
  • lp5_phase.zip
  • LTspice_Educational.pdf
  • LTspice_VDMOS_param_ksubthres.zip
  • Mains Filter2.asc
  • Min_vdrop_vs_temp.zip
  • Model_change_param_ako.asc
  • Model_Selection_ako.asc
  • Modulated Sawtooth Generator.zip
  • Mosfet_capacitance_ciss_coss_crss1.asc
  • Mosfet_cap_ciss_coss_crss1a.asc
  • MOSFET parameter sweep.zip
  • mos_param_visibility.asc
  • moving_average1.zip
  • nand_osc1.asc
  • nmos_model.asc
  • NoiseFigure_opt1.zip
  • opamp_rout.asc
  • oscillators.zip
  • passing_params_hierarchy_2.asc
  • passing_params_hierarchy_2p.asc
  • Photo Diode Simulations.zip
  • pi-controller-2.asc
  • pi_e.asc
  • pink_ac_source.asc
  • plot_ energy_charge_flux.zip
  • Plot Panes.zip
  • Power-Factor.asc
  • pwm.asc
  • PWM_FREQ_DUTY1.asc
  • QTLP690C_Eg.asc
  • Quadrature_fm_demodulator.zip
  • Ramp_table_if.asc
  • rdson_temp.asc
  • R-formula_time.asc
  • rout_dc_op_tf_ac_tran.zip
  • shot_noise.asc
  • skin_effect2.asc
  • solar_diode_check.asc
  • stepped_plot_panes.zip
  • step_recovery_diode.asc
  • Sweep with_B-source_Modulate.asc
  • SW_subckt.zip
  • tc_of _res.asc
  • TIA_universalopamp2.asc
  • Time domain noise sources.zip
  • time_var_resistor.asc
  • too_high_gmin.asc
  • Transient analysis of a crystal.zip
  • Transistor Model 2N6517.zip
  • Transistor Models 2N4401.zip
  • triggered_pulse__v_tline_bv.asc
  • URC_line.asc
  • Using Infineon OPTIMOS models.zip
  • Using MOSFET models.zip
  • vco_table_poly.asc
  • view_param.asc
  • voltage_periodic_ramp1.asc
  • white_gauss1.asc
  • Z-imp-freq table.zip
  • Z_imp_test_mag_r_i.zip
  • zin_rlc1.asc
