Hello I saw a good idea about lead in / out when cutter compensation was not supported by machine ; I run GRBL on plasma machine, works good , but I have trouble with the lead in / out , I saw Chrisitan started a hack with the lead in / out, how did this go ? can I kindest check the code / hack ? ??
He wrote: "My particular interest is in code suitable for a plasma cnc to eat, specifically the linuxcnc plasmac component. So I'll tinker away on the lead-in/out, see where I get to and then perhaps move on to adding new layer "tags" to support auto recognition of outside and inside cuts so correct cut direct and compensation can be applied. Assuming something similar is not already in place."
