I think you could also produce this by using the normal mill postprocessor. Just give it a try, you will find the description how to do this in the above linked Wiki too.
you can try to use the following values for the A Axis, the rest should be similar to the standard. With the limitation of Arcs, i am not sure how this could work with a A axis. ...
