Diverse Modelle von Bordodynov und Sborka
Liste:
NE85630/CEL
2SC5227A-5
BFR540
FGL40N120AND
DMN65D8L
MTM23223
DZ23223
L709CE
k1v14
TLP3120
TLP172A
LM329DZ
Si9987
MC33063A
ZXCT1022
AD1584
L200CV
L-93WSRSGC
BridgeRectifier
ntc_resistor
ntc_resistorT
PDTA143XT
PDTA143ET
PDTA144ET
PDTC143ET
PDTC144ET
DDTC144ECA
DDA143TU
DDA144EU
DDA123JU
MRF9411
RF9411
ATF34143
BC847BS
BFS481
BFS481_IN
BC857BS
BCM857BS
BCM857BV
BC847BV
BC847BPN
BC847BVN
EMZ52
KT3123A-2
MRF873
BFG31_PH
NE68033
NE68133
NESG2021M05
2SC5006
BFR181
BFR106
MRF901
NE677M04
bfg591
BLT81_PH
BFM505_PH
BFM520_PH
BFU520W
BFT25A
BFQ790
CPH6003A
UPA800T
BC860C_SIE
BC850C
BF824
NE97733
BBY65-02V
74xx123
74xx123q
H11L1
6N136
6n137
VO615A
HCNR200
hcpl3180
pc357nt
hcpl-3140
AOD130A
sfh2400
sfh2400_4
ZXRE125
LM113
BZG03C220
AD1580
ZRC250
BPW34S
BPW34S_Lx
OP905
SFH203FA
S6045_1
S8890-05
NE555_R
555
7555
LMC555
74AHC1G14
74AHC1G02
74AHC1G08
74AHC1G04
SN74AHC1G00
AD8541
AD8628
AD8603
LM358_TI
LM358
OPA820
OPA128
OPA128E
OPA847
OPA171
OPA333
OPA342
OPA360
OPA360
AD8552
LMP7721
MCP6541
MCP6541_my
MCP6401
MCP6231
MCP6291
MCP6051
OPA659
opa627
OPA350
TLV314
ad8065_my
opa627e
OP177
OPA177
TS95X
OPA364
OPA365
OPA134
OPA134
OPA2134_my
OPA2342_my
OPA2354
OPA655
OPA657
OPA657schm_F7
OPA657schm_F8
OPA657schm_F10
OPA657schm_F9
OPA657schm_F1
OPA656
AD820AR
TLV2221
TLV226x
OPA846
MAX9914
OPA336
OP284
ADA4817-1
LMV951
OPA121
opa354
OPA340
MAX4323
MAX4323_S
CA3140
mcp6041_my
MCP6041
mcp6021
mc34182
ad8611
LM393
LMC6772BIM
lmc6772b
lmc7215
LMC7225/NS
lmv331
lmv7271
max961
LM7301
AD8055an
AD8330
AD8330_H1
AD8330_H2
max965
BAT54A
BAT54C
BAS70_06
BAS70_05
BAS70_04
BAT54S
BAT754S
bav199
bav99
bav23s
Sw10to1
Sw10to1Short
sw12to1
Sw12to2
Sw10to2
SLIDE_SWITCH_STSSS2231
MPS-580D-G
transform2
transform3
transform4
XFMR1
XFMR2
4N39
4N40
Lazer
SPL_PL90_3
ILPI-137A
BCV61c
bcv62c
KT972A
KT973A
BCX38B
FZT604
FZT605
FZT705
BC517
BC516
TIP120
TIP121
TIP122
TIP127
kt3165a
bft92
BFT92W
bft93
bfr92
Bfr93a
bfp405
BFP620F
BFG425W
D44H8
PSMN038-100YL
PSMN028-100YS
VN2460
FDH44N50
irfbe20
STP20NM60FD
ntb52n10
stp7nb80
STP11NK50Z
PSMN026_80YS
PSMN013_80YS
TN0200K
esd_nch
AO3416
AO3415
FDN359AN
FDN304p
ZXMN2A01F
DN3545
SI2308DS
irlml6302
RSU002P03
FDG6320C_N
FDG6320C_P
PMV20XN
BSS138/FAI
BSS138
Si4497DY
fdv304p
AO3419
TP0610K
ZXMP10A13F
ZXMN10A07F
VP2450
FDN352AP
NDS351AN
irlml2060pbf
irlml9303pbf
irlml0100
TN0200T
TN0201KL
TN0201K
NDS352P
MTD20P06HDL
MTD2955V
MTD3055V
ZVP2120G
FDC5614P
FDN5618P
HUF76639
irlml0030trpbf
Si2337DS
Si2309DS
NDS7002A
Si7402DN
BSS192P_L0
BSS192P_L0
ZVP4525G
ZVP4525Z
ZVP4525E6
ZVP4424A
ZVP4424C
ZVP4424G
FDV305N
fdv303n
fdv302p
MCH3383
fdv301n
irlml6346trpbf
MTM981400BBF
DZ98140
irll014n
irlml2502
irll110
irf7311
irf7494
irf7495
fdc604p
FDC645N
nds336p
nds335n
FDN327N
nds332p
fdn335n
NDS0605
FDC6330Ltemp
FDW252P
BUZ341
NDT456P
irlb3036pbf
BS250P
ZXMP3A13F
ZXMN2A02N8
IRF9Z34
irf9z34n
FDR838P
irf7478
irl530n
irf2805
irfl4105
irll2705
irl2505s
ztx415
LM3352MTC-3.3
MC33063
tl494
tl494
tl494h
tl494h
CD4541B
L6920D
ZXLD1350
TL431AS
TL431ED
TLV431_TI
TLV431
tlv431_my
ZR431L
ZXRE060
ZXRE160
TransBertotti
NIMH1
NIMH
TLV3491
TLV3501
acpl-c87at
OPA192
FGH25N120FTDS
irg4pc50w
IPD70N03S4L_04_L0
IPB80N03S4L_02_L0
irls3034
FQPF47P06
OPA1611
ZHT431
MRF3866
2N5944
MFR406
MRF450
MRF492
TS321
LMV761
OPA388
MMBR941
XMBR941
BFU790F
  • Sborka.lib
Hi, wie binde ich die Bibliothek in LtSpice ein, damit ich Zugriff auf den Mosfet bekomme?
Direktive .inc Sborka.lib in den Schaltplan schreiben.
Wobei Sborka.lib im gleichen Verzeichnis wie der Schaltplan sein muss.
Es kommt darauf an, ob der Mosfet in der Bibliothek als Model oder als Subcircuit definiert ist.
Um konkrete Hilfe zu bekommen, ist es immer gut, genaue Informationen mitzuliefern.
Du schreibst:
"... den Mosfet" -- Du weisst, welcher das ist, aber wir, die Leser Deiner Nachricht, wissen das nicht.
Für den Fall, dass der Mosfet als Subcircuit vorliegt, braucht man auch ein Symbol dafür.
Ausserdem haben nicht alle die besagte Sborka.lib auf ihrem Computer, obwohl man sie hier
herunterladen kann.
Um Hilfe zu bekommen, musst Du schon ein bisschen mitwirken. Gedanken lesen können wir noch nicht . . . ;-)
Es wäre also schon gut, wenn Du uns wenigstens den Namen des Mosfets mitteilen würdest.
Ich möchte den "PMOS IRF9Z34" in LT spice einbinden. Ich habe dafür jetzt die " Sborka.lib" gefühlt in jedem Ordner abgelegt und wie oben beschrieben die "Direktive .inc Sborka.lib" in den Schaltplan geschrieben. Mein Wunschgedanke war nun, dass der Mosfet dann jetzt unter den entsprechenden PMOS bei "Pick new MOSFET" zu finden ist. Das ist aber leider bei mir nicht der Fall.
Es reicht, wenn die Lib beim Schaltplan ist.
Poste mal Deinen Schaltplan. Dann kann man Dir besser helfen.
Hier, wie in der MOSFET-Auswahl zu sehen, fehlt der IRF9Z34 leider immernoch. Die Sborka.lib liegt bei mir direkt unter Documents\LTspiceXVII ab, wo auch mein Schaltplan liegt. Weiter im Verzeichnis unter "\Documents\LTspiceXVII\lib\sub" liegt die Sborka.lib bei mir nochmal, da dies der einzige Ordner ist, in dem die Endung .lib überhaupt mal vorkommt, hatte ich gedacht dass diese dort gut hinpasst :D
Das funktioniert so nicht.
Ein Bauteil in die standard Lib zu übernehmen ist ein anderes Thema!
Hier ein Beispiel mit einem IRFZ44N
Du musst mit CTRL und rechter Maustaste auf das (PMOS) Symbol klicken.
Im nun erscheinenden Menu Deine Eingaben machen. Bei Präfix musst ein X rein.
Den PMOS Name (IRF9Z34) bei Value eintragen.
Ich würde nie ein Bauteil in die standard Libs übernehmen, ausser ich wäre mir sicher, dass ich dieses Teil immer und oft brauche!
Den Fehler hab ich Anfangs auch gemacht.
Hinzu kommt, dass LTspice von Analog nicht mehr \Documents\LTspiceXVII\lib\sub oder sowas gebraucht, sondern \appdata oä.
Wenn Du wirklich ein Bauteil in die standard Lib integrieren willst, wird's kompliziert.
Es reicht nämlich nicht, nur die Files ins betreffende LTspice standard Verzeichnis zu kopieren.
Man muss dies mittels LTspice machen. Sonst wird man die zusätzlichen Teile nie zu Gesicht bekommen.
Ich habe mir schon gedacht, dass dieser Mosfet ein Subcircuit ist. Das interne Symbol für den Mosfet-Transistor ist nur für Modelle geeignet, nicht für Subcircuits. Da brauchst Du ein auf den Mosfet zugeschnittenes Symbol. Ich lade das Symbol mit hoch.
Das Symbol, die Sborka.lib und der Schaltplan müssen im gleichen Ordner sein.
Wie findest Du das Symbol, weisst Du das?
Schau Dir den folgenden Screenshot genau an:
Normalerweise ist für die Bauteilewahl der Ordner unter lib/sym voreingestellt, aber da kann man, weil Dropdown-Menu, auch den übergeordneten Ordner (Ordner, in dem der Schaltplan abgespeichert wurde) wählen, bei mir ist das /30_MOSFET. Und wie Du siehst, wird da das entsprechende Symbol gelistet. Danach sollte eigentlich alles ok sein.
Spicer's Methode geht natürlich auch.
  • IRF9Z34.asy
  • irf9z34n.asy
Er kann doch auch das bereits integrierte standard Symbol PMOS nehmen...
Ja klar, das ist Geschmackssache/Gewöhnung. Ich persönlich arbeite lieber mit getrennten Symbolen, auf die Schnelle ist das mit dem Standardsymbol schneller und damit vorteilhafter.
Ausserdem enthalten die einer Lib zugeordneten Symbole mitunter Parameterwerte, die dann in dem Standardsymbol natürlich fehlen!
P.S.: Ich wollte auch nur helfen und niemandem auf die Füsse treten, sorry!
@RudiS Ich habe selber auch keinen Plan, wenn's um den Unterschied von Sub und was Anderem geht.
Du bist niemandem auf die Füsse getreten :D
@kevo1998 möchte wohl erstmal, dass seine Schaltung ohne Fehler simuliert wird ;)
Vielen Dank @spicer für deine freundliche und detaillierte Beschreibung. Ich konnte den Mosfet nun integrieren und meine Schaltung läuft :)
